Auto-Layout -> Make a Grid
  • February 2, 2021
  • 19 replies
  • 4232 views
Pedro_Canelas
I love the Auto-layout feature but is a pity that I need to choose between horizontal or vertical. Why not both?
My suggestion is an option inside Auto-Layout called Grid that would allow me to choose the amount of columns and rows and create a grid using a smart layout.
aolko
  • February 23, 2021
That would be a nice feature. However, i’d say there should be auto rows and columns, so they are not fixed. see: css grids
BorojiDesignInc
Having CSS Grid would be amazing 😍
Wolfgang_H
They have this in XD, and it’s great. I switched from XD to Figma, and overall, Figma is better. But I do miss that feature (and being able to move layers inside instances)
BorojiDesignInc
Here is Webflow Grid UI for inspiration:
image 3
0xtutti
  • November 8, 2021
Having grids would be amazing.
Nate_Butler
I’d really love to see this, it would help a lot with layer hygiene. It also aligns closer with the way things are actually built in code, as elements in html and flex box are able to wrap.
Viraj_Duvedi1
If there is a beta or even an alpha, I’ll be happy to join in to test!
Pixelsage
  • February 27, 2022
Yes, a grid option would be fantastic for autolayout!
Klesus
  • March 4, 2022
I would love this for the simple reason of making component sets more manageable. Adding variants after the fact is a PITA when you have to resize the border all the time. It would be soooooo convenient if the component set could expand/shrink dynamically.
Flo
  • March 28, 2022
Dear Figma-Devs, please do this! Kind regards
cryonyx
  • April 21, 2022
Fully support this feature, I miss it so much when preparing the landing pages.
Luca9
  • June 23, 2022
Figma should mimic both CSS grids and Flexbox properties exactly the way that HTML does, at that point it’s going to be a major step forward in filling in the gap between design and development. Webflow, as someone mentioned, is a perfect example of how feasable that can be.
Josh_Loya
  • November 28, 2022
+1
This would simplify a lot of the hierarchical boilerplate needed to simulate this with auto-layout (flexbox)
deletedlc
  • February 17, 2023
honestly kinda sad that XD had this since really early versions
A.J_Kandy
  • February 22, 2023
Absolutely. We need equivalent behaviour to CSS Grid and Flexbox in Figma (including subgrid).
David_Simpson
  • November 20, 2024
Hey, FIgma is there any word on bringing grid functionality to auto layout? Designing responsive grids should be simple, but choosing a column or row layout can misalign one or the other when cell content width and or height varies. This means manually adjusting for different width mockups.
Gayani_S
  • November 20, 2024
Hey @David_Simpson, thanks for sharing your feedback! I understand how important responsive grids are for your workflow. While I can’t share any updates just yet, I’ll make sure to pass this along to the team for consideration.
Thank you!
Matthew_Ryan
  • February 19, 2025
Another +1 for responsive CSS grids.
The feature named “grid” in Figma is not at all the same thing.
Damian_Oczki
  • Active Member
  • March 17, 2025
+1, really needing this more and more with every project.
Figma needs a layout that works like CSS `display: grid`, so that we don’t have to nest flexbox containers anymore.
