Last login: Wed Sep 15 10:56:41 on ttys000
~ dig d56xex7lpkwk8.cloudfront.net ✔ at 10:57:53
; <<>> DiG 9.10.6 <<>> d56xex7lpkwk8.cloudfront.net
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 28267
;; flags: qr rd ra; QUERY: 1, ANSWER: 4, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 1280
;; QUESTION SECTION:
;d56xex7lpkwk8.cloudfront.net. IN A
;; ANSWER SECTION:
d56xex7lpkwk8.cloudfront.net. 5 IN A 13.35.125.13
d56xex7lpkwk8.cloudfront.net. 5 IN A 13.35.125.60
d56xex7lpkwk8.cloudfront.net. 5 IN A 13.35.125.59
d56xex7lpkwk8.cloudfront.net. 5 IN A 13.35.125.49
;; Query time: 3 msec
;; SERVER: 192.168.3.1#53(192.168.3.1)
;; WHEN: Wed Sep 15 10:58:08 CST 2021
;; MSG SIZE rcvd: 121
~ curl -v -k https://www.figma.com/figbuild-artifacts/figma_app.d8f8e3055bd56f5144129cb5fc2481e9.min.css.br > /dev/null
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0* Trying 13.35.125.60...
* TCP_NODELAY set
* Connected to www.figma.com (13.35.125.60) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* successfully set certificate verify locations:
* CAfile: /etc/ssl/cert.pem
CApath: none
* TLSv1.2 (OUT), TLS handshake, Client hello (1):
} [227 bytes data]
* TLSv1.2 (IN), TLS handshake, Server hello (2):
{ [100 bytes data]
* TLSv1.2 (IN), TLS handshake, Certificate (11):
{ [4569 bytes data]
* TLSv1.2 (IN), TLS handshake, Server key exchange (12):
{ [300 bytes data]
* TLSv1.2 (IN), TLS handshake, Server finished (14):
{ [4 bytes data]
* TLSv1.2 (OUT), TLS handshake, Client key exchange (16):
} [37 bytes data]
* TLSv1.2 (OUT), TLS change cipher, Change cipher spec (1):
} [1 bytes data]
* TLSv1.2 (OUT), TLS handshake, Finished (20):
} [16 bytes data]
* TLSv1.2 (IN), TLS change cipher, Change cipher spec (1):
{ [1 bytes data]
* TLSv1.2 (IN), TLS handshake, Finished (20):
{ [16 bytes data]
* SSL connection using TLSv1.2 / ECDHE-RSA-AES128-GCM-SHA256
* ALPN, server accepted to use h2
* Server certificate:
* subject: CN=*.figma.com
* start date: Mar 2 00:00:00 2020 GMT
* expire date: Mar 26 23:59:59 2022 GMT
* issuer: C=GB; ST=Greater Manchester; L=Salford; O=Sectigo Limited; CN=Sectigo RSA Domain Validation Secure Server CA
* SSL certificate verify ok.
* Using HTTP2, server supports multi-use
* Connection state changed (HTTP/2 confirmed)
* Copying HTTP/2 data in stream buffer to connection buffer after upgrade: len=0
* Using Stream ID: 1 (easy handle 0x7fdc4880e000)
> GET /figbuild-artifacts/figma_app.d8f8e3055bd56f5144129cb5fc2481e9.min.css.br HTTP/2
> Host: www.figma.com
> User-Agent: curl/7.64.1
> Accept: */*
* Connection state changed (MAX_CONCURRENT_STREAMS == 128)!
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0< HTTP/2 200
< content-type: text/css; charset=utf-8
< content-length: 209551
< date: Wed, 15 Sep 2021 02:58:18 GMT
< last-modified: Fri, 10 Sep 2021 01:29:52 GMT
< etag: "e8cb8249fbd70f675a67f411283da084"
< x-amz-server-side-encryption: AES256
< cache-control: max-age=31536000
< content-encoding: br
< x-amz-version-id: .X.MDhTts_GTlLdUeiR5xDGcrDhvFDRO
< accept-ranges: bytes
< server: AmazonS3
< x-cache: Miss from cloudfront
< via: 1.1 5750cab2900ee4d5c9d37c11c5a3d474.cloudfront.net (CloudFront)
< x-amz-cf-pop: SFO5-C1
< x-amz-cf-id: pkw47KpOp4mv9sXhGTqOwcylikm_IGrU6TPlNoE-10ybl0gmY6K_nQ==
{ [15945 bytes data]
100 204k 100 204k 0 0 149k 0 0:00:01 0:00:01 --:--:-- 149k
* Connection #0 to host www.figma.com left intact
* Closing connection 0
~ curl -v -k https://www.figma.com/figbuild-artifacts/figma_app.b7d69b32043118bec2bfd56257209415.min.js.br > /dev/null
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0* Trying 13.35.125.49...
* TCP_NODELAY set
* Connected to www.figma.com (13.35.125.49) port 443 (#0)
* ALPN, offering h2
CApath: none
} [227 bytes data]
{ [100 bytes data]
{ [4569 bytes data]
{ [300 bytes data]
{ [4 bytes data]
} [37 bytes data]
} [1 bytes data]
} [16 bytes data]
{ [1 bytes data]
{ [16 bytes data]
* Using Stream ID: 1 (easy handle 0x7f7f9880e200)
> GET /figbuild-artifacts/figma_app.b7d69b32043118bec2bfd56257209415.min.js.br HTTP/2
> Host: www.figma.com
> Accept: */*
< content-type: application/javascript; charset=utf-8
< content-length: 2173934
< date: Wed, 15 Sep 2021 02:58:26 GMT
< last-modified: Thu, 09 Sep 2021 19:02:18 GMT
< etag: "ee7c27726c0aff60d1658c97c08d6d25"
< x-amz-version-id: M.mQN8dpqal8BIItwzcmhyMzWRsDu2QP
< server: AmazonS3
< via: 1.1 208eb126ebe99fd5accb034c84a1eeca.cloudfront.net (CloudFront)
< x-amz-cf-id: JQhtn_rtRWh3fkORC6pe9-9dYtpOtSdrm9pcv58knQTJiu6i1eMeSQ==
{ [1515 bytes data]
100 2122k 100 2122k 0 0 996k 0 0:00:02 0:00:02 --:--:-- 996k
~ curl -v -k https://static.figma.com/fullscreen/a4018f2d15bff54a7a22e3143c5bbbf551007e35/compiled_wasm.wasm.br > /dev/null
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0* Trying 13.35.0.95...
* TCP_NODELAY set
* Connected to static.figma.com (13.35.0.95) port 443 (#0)
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0* ALPN, offering h2
CApath: none
} [230 bytes data]
{ [100 bytes data]
{ [4569 bytes data]
{ [300 bytes data]
{ [4 bytes data]
} [37 bytes data]
} [1 bytes data]
} [16 bytes data]
{ [1 bytes data]
{ [16 bytes data]
* Using Stream ID: 1 (easy handle 0x7fe835008200)
> GET /fullscreen/a4018f2d15bff54a7a22e3143c5bbbf551007e35/compiled_wasm.wasm.br HTTP/2
> Host: static.figma.com
> Accept: */*
0 0 0 0 0 0 0 0 --:--:-- 0:00:02 --:--:-- 0< HTTP/2 200
< content-type: application/wasm
< content-length: 2312243
< date: Wed, 15 Sep 2021 02:58:34 GMT
< last-modified: Thu, 09 Sep 2021 17:16:51 GMT
< etag: "9582584cfd1a513fe47c44c94b6dfbb0"
< x-amz-version-id: oNj2OeJDfwRBRx1PAonTo72iX1fyPw8z
< server: AmazonS3
< via: 1.1 578c2dbb800e023bdb12624c5b05f3a7.cloudfront.net (CloudFront)
< x-amz-cf-pop: TPE52-C1
< x-amz-cf-id: xfmU9vydJYeEoMRzQe61XtPV5ZE5MB2DelRdmFTisvHrVJpqxquT0Q==
{ [5792 bytes data]
66 2258k 66 1512k 0 0 110k 0 0:00:20 0:00:13 0:00:07 148k^C
~ curl -v -k https://static.figma.com/fullscreen/a4018f2d15bff54a7a22e3143c5bbbf551007e35/compiled_wasm.js.br > /dev/null
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0* Trying 13.227.252.59...
* TCP_NODELAY set
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0* Connected to static.figma.com (13.227.252.59) port 443 (#0)
* ALPN, offering h2
CApath: none
} [230 bytes data]
{ [100 bytes data]
{ [4569 bytes data]
{ [300 bytes data]
{ [4 bytes data]
} [37 bytes data]
} [1 bytes data]
} [16 bytes data]
{ [1 bytes data]
{ [16 bytes data]
* Using Stream ID: 1 (easy handle 0x7f96bc80e800)
> GET /fullscreen/a4018f2d15bff54a7a22e3143c5bbbf551007e35/compiled_wasm.js.br HTTP/2
> Accept: */*
< content-length: 87533
< date: Wed, 15 Sep 2021 02:58:52 GMT
< etag: "4fd244c4ba7cc03b43eed0f1f64166e6"
< x-amz-version-id: ks0op_zDz_gLuxUeBbxOlIPJpJdkTB4N
< server: AmazonS3
< via: 1.1 a691085135305af276cea0859fd6b129.cloudfront.net (CloudFront)
< x-amz-cf-pop: SIN52-C3
< x-amz-cf-id: HG9xJ5gf1EvXSk8uV0P0Ezi01kvO9GKnT02zSt7YnlLRiZFm9BLjSA==
{ [8188 bytes data]
100 87533 100 87533 0 0 26168 0 0:00:03 0:00:03 --:--:-- 26160
* Connection #0 to host static.figma.com left intact
~ traceroute d56xex7lpkwk8.cloudfront.net ✔ took 3s at 10:58:53
traceroute: Warning: d56xex7lpkwk8.cloudfront.net has multiple addresses; using 13.35.125.13
traceroute to d56xex7lpkwk8.cloudfront.net (13.35.125.13), 64 hops max, 52 byte packets
1 rt-ac68u-c690 (192.168.3.1) 1.781 ms 1.339 ms 1.260 ms
2 router.ctc (192.168.2.1) 1.927 ms 2.076 ms 1.802 ms
3 100.100.128.1 (100.100.128.1) 3.560 ms 3.583 ms 4.952 ms
4 222.190.36.77 (222.190.36.77) 4.125 ms 4.256 ms 3.923 ms
5 * 61.155.228.137 (61.155.228.137) 7.451 ms
222.190.59.161 (222.190.59.161) 4.848 ms
6 202.97.29.105 (202.97.29.105) 10.273 ms
202.97.74.149 (202.97.74.149) 11.628 ms
202.97.19.253 (202.97.19.253) 14.791 ms
7 * 202.97.50.134 (202.97.50.134) 19.353 ms
202.97.64.182 (202.97.64.182) 10.528 ms
8 202.97.51.241 (202.97.51.241) 11.371 ms
202.97.83.62 (202.97.83.62) 11.780 ms
202.97.51.241 (202.97.51.241) 16.807 ms
9 202.97.27.210 (202.97.27.210) 196.323 ms
202.97.50.114 (202.97.50.114) 270.861 ms
202.97.27.210 (202.97.27.210) 263.559 ms
10 202.97.50.58 (202.97.50.58) 241.721 ms 155.068 ms
202.97.86.177 (202.97.86.177) 329.235 ms
11 218.30.53.6 (218.30.53.6) 167.495 ms 166.978 ms 166.979 ms
12 54.240.242.207 (54.240.242.207) 149.837 ms
54.240.242.209 (54.240.242.209) 178.467 ms
54.240.242.205 (54.240.242.205) 153.234 ms
13 52.93.47.127 (52.93.47.127) 163.394 ms
52.93.47.125 (52.93.47.125) 164.378 ms 153.048 ms
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
19 server-13-35-125-13.sfo5.r.cloudfront.net (13.35.125.13) 163.651 ms 151.308 ms 153.180 ms
~ ✔ took 1m 30s at 11:00:28
