PublishStatus
Graham_Paterson
Looking for some details about PublishStatus and getPublishStatusAsync().
As far as I can tell getPublishStatusAsync() always returns UNPUBLISHED outside of the library file itself. Am I missing something here?
Steps I took
  1. create new file that has access to team library
  2. Insert instance from library (by dragging from asset panel)
  3. get main component from instance using getMainComponentAsync()
  4. run getPublishStatusAsync() on main component
  5. results UNPUBLISHED
Best answer by tank666
That’s right. This API is designed for library files.
  • 4873 replies
  • March 25, 2024
Graham_Paterson
Ah okay, just to confirm using pseudocode below:
Library File
↳ ❖ Published Component
↳ ◇ Instance (of ❖ Published Component)
instance.mainComponent.getPublishStatus == 'CURRENT' | 'CHANGED'
Working File
instance.mainComponent.getPublishStatus == 'UNPUBLISHED'
  • 4873 replies
  • March 25, 2024
The UNPUBLISHED value can also be present in a library file.
Right!
Graham_Paterson
Okay great, thanks for the help!
