Hello pls i’m having issues with my prototype dispaly, it’s only showing 1/1 frame out of about 6 frames. I tried to cancel all interactions but cant even see that option when i right click on the artboard while on prototype tab. kindly help pls as im kinda stranded
Thanks
Hey, I think it was brought upon by an update to the platform. Under the prototype panel, if you have a flow “started” then it will assume that the first screen is the only screen it should display. But since the frames are not connected you will never be able to make your way to the other screens.
Under the ‘Prototype’ Panel I selected the FLOW and pressed the “delete” key on my keyboard and did away with it. It solved the problem.
