Describe the problem your experiencing and how your idea helps solve this
I’m experiencing a lot of lag recently. Whenever I add components, use variants, swap component via the design panel, even removing prototype connections. The UI freezes, I can’t select anything and It takes sometimes like 10 seconds for the UI to respond.
Adding components from the new Insert component modal also causes the UI to freeze. I can’t do anything until it snaps out of it.
I’m on a M1 MacBook Pro and I’m using the desktop app. I’m also on the interactive components beta. Maybe the “lag” is related the interactive components beta. -
Add as much context as possible (screenshots, Figma files, mockups, etc.)
It happens when:
- Using variant props.
- Adding a component to the canvas (the components has variants).
- Swap the component using the design panel.
- Removing prototype connections.
It may happen with other interactions but these are the ones I’ve notice the huge lag on.
- Ask questions to bring the community into the conversation
Has anyone else experiencing this? It has been happening for a week now.
