Figma Slides improvement - Footer as a component with pagination
Like in the design tool, I will be interesting to have components in Figma Slides. That way, designers can create templates for the company and non designer have only one place to change the footer on all slides. If we can have the option to add pagination to the footer or anywhere it will be a big plus.
I noticed that Figma Slides is already assigning slide numbers to each slide you create, so I’m hoping it will be easy in the future to create a slide footer component and assign a built-in slide number variable to it. For now, I created a slide components library in another file and am pulling my footer in from there, but I would like to be able to do the automatic slide number thing.
Thanks for the feedback!
We’ll pass this onto the Slides team for future consideration.
Agreed…manually editing things like the “Company” and “Date” on every slide can be a daunting undertaking!
It would be nice to update the header and footer on one slide, have the option to update all slides and not have to write the same thing several times for every slide
Hi @dvaliao
Manually paginating slides is really tedious.
Could you share with us the schedule for the next Figma Slides updates?
Our company needs visibility to know whether we should continue to use Figma Slides or not.
Thank you
Hi @dvaliao
Thank you
