shijia.me
May 13, 2025
Extended/No Expiration Personal access tokens
  • May 13, 2025
  • 18 replies
  • 1608 views
  • before 🤗
Previously, you could generate a [no expire] token
  • now 😔
If users rely on tokens to access the figma open api, forgetting to replace expired tokens can cause serious problems.
The expiration date of the limited period will cause the figma token to no longer have usage value.
Hi ​@shijia.me, thanks for reaching out!
Our team is investing in security improvements to our API, so as a first step, we decided to remove the ability to create non-expiring personal access tokens.
shijia.me
shijia.meAuthor
May 27, 2025
Thanks for your reply.
Please provide alternatives instead of removing this feature.
Dave Rivera
Hi ​@djv!
Thank you for elaborating on the situation.
Could it be possible to have a more extended option? For example, 6 months? The maintenance of updating pipelines and machines every 3 months (90 days) is too high for us. So a longer extended period for us would be great, but ideally a non-expired / yearly period would be a better option
Hey All, thanks for the additional feedback!
We’ve updated this topic into a feature request, and we’ve passed this along to the team for future consideration.
While this isn’t on the team’s immediate pipeline, they will be monitoring this topic to collect feedback from the community.
Robert Willemelis
I value the limitation for security purposes — but:
As I already mentioned on X, I’d really appreciate it if this limitation could be extended or removed for read-only tokens.
Idea 1:
Adjust the restriction based on the file’s visibility status — e.g. whether it’s private, public, or something in between. Introducing a third state like “confidential” or “sensitive” could help better reflect the security context.
Idea 2:
Figma could implement an AI-based check to determine whether a token might pose a security risk, depending on its scope or the sensitivity of the data it grants access to.
Idea 3:
Log the usage of the token and allow users to monitor it — for example, by seeing which hosts or users are making requests. Similar to "known device" features on other platforms, users could then confirm, “yes, that’s me.”
Idea 3a:
Allow passing a label or tag as a second argument when registering the token, to help track its usage more easily.
Thanks for your feedback, ​@Robert Willemelis!
I’ll pass this onto our team for their consideration.
sshkalikov
Hi folks, please consider making it possible to create long-lived, readonly api tokens.
We need a way to periodically access Figma API from CI pipelines. With the current tokens lifetime, someone is going to have to manually update the token every 3 month, which is not a great solution, to say mildly.
Tobias Pickel
This is a showstopper for running code-connect on the ci and thus using it in a professional context.
Please let us have a workspace token or something similar that does not expire.
kelly.lawrence.thesuite
Any chance the team could make time for this in Q4 2025? This is a huge QOL issue. I really only care about the read permissions. Having to update that every 3mo is brutal.
ksn
Hey ​@kelly.lawrence.thesuite - I understand that this may not be the best answer, but we don’t have any available timeline we can provide or guarantee at the moment. Can confirm that it has been noted by us internally. Keep an eye on our blog -- updates are posted there (and you might find some other interesting features rolled out recently that may be worth exploring on your end): https://www.figma.com/blog/
