Hello everyone,
I'm facing a significant workflow issue when exporting from Figma to React, and I'm hoping the community can help me find a solution.
Current Situation:
- My Figma file uses Untitled UI design system with properly configured variables (colors, spacing, typography, border radius, etc.)
- I've verified the variables are correctly set up:
Colors/Brand/500,spacing-md,Text md/Semibold,radius-lg, etc. - When I export/generate code from Figma, I get React code with custom Tailwind classes instead of Untitled UI components
The Problem (with real examples):
What Figma exports:
jsx
// Button
<div className="shadow-[0px_0px_0px_1px_rgba(10,_13,_18,_0.18)_inset] rounded-num-8 bg-brown border-gray-400 border-solid border-[2px] overflow-hidden flex items-center py-2 px-num-12 gap-1">
<div className="relative leading-5 font-semibold">Add User</div>
<img className="w-5 relative max-h-full" alt="" />
</div>
// Badge
<div className="shadow-[0px_1px_2px_rgba(10,_13,_18,_0.05)] rounded-tl-num-6 bg-whitesmoke-100 flex items-center py-num-2 px-1.5 gap-1">
<div className="h-2 w-2 relative">
<div className="absolute top-[1px] left-[1px] rounded-[50%] bg-darkorange w-1.5 h-1.5" />
</div>
<div className="relative leading-num-18 font-medium">offen</div>
</div>
// Input
<div className="shadow-[0px_1px_2px_rgba(10,_13,_18,_0.05)] rounded-num-8 bg-white border-lightgray border-solid border-[1px] overflow-hidden flex items-center py-2 px-num-12 gap-2">
<div className="flex-1 flex items-center gap-2">
<div className="flex-1 relative leading-6">Search</div>
</div>
</div>What I need (Untitled UI React components):
jsx
// Button
<Button variant="primary" size="md" iconTrailing={<Plus />}>
Add User
</Button>
// Badge
<Badge color="warning" size="sm" dot>
offen
</Badge>
// Input
<Input
placeholder="Search"
iconLeading={<Search />}
shortcut="⌘K"
/>Specific Issues:
- Non-standard classes:
rounded-num-8,px-num-12,py-num-2,rounded-num-6instead of standard Tailwind - Generic color classes:
bg-brown,text-darkslategray,bg-whitesmoke-100instead of design tokens - No component structure: Raw HTML divs instead of semantic Untitled UI components
- Inline shadows: Long shadow values instead of using Untitled UI shadow utilities
- No Code Connect mapping: Figma doesn't know how to map to actual React components
My Questions:
- Has anyone successfully configured Code Connect for Untitled UI components to map Figma layers to React components?
- Are there specific Figma plugins designed for Untitled UI export?
- Is there a post-processing script or tool that can transform the exported code to use proper Untitled UI components?
- Should I be structuring my Figma file differently to get better exports?
What I've Tried:
- Verified all Untitled UI variables are properly configured in Figma
- Used Figma's Dev Mode export
- Checked for Code Connect configuration (none found)
Technical Environment:
- Design system: Untitled UI
- Target framework: React + Untitled UI component library
- Build tool: vscode
Any guidance on bridging this gap between Figma designs and production-ready React code would be incredibly helpful. I'm open to solutions involving Code Connect, custom plugins, transformation scripts, or workflow adjustments.
Thank you in advance for your help!
