How to see which components/variables are assigned to which components/variables?
  • June 9, 2025
  • 34 views
Derek Hatfield
Is there a way in Figma, or a plugin, to give me a way to see or find out where a variable is being used in a component library. For example, how can I find out where “background.primary” is being used?
Also, with that being said, is the a plugin that will give me all the variables for a single component?
Thanks!!
giliard
  • June 9, 2025
Seems like that does not exist today, not in the same way we can view/inspect regular styles.
I found this plugin that lists the variables based on a selection, not sure if this helps, but was the closest that I got.
Kip
  • November 11, 2025
Seeing variable usage across an entire file would be extremely useful.
In my case the design architecture of our DS was done by someone that has moved on and now I manage it; I didn’t set the properties and don’t know the intent or ramifications if I make modifications.
Use case:
We have a variable for bg-error-primary that is Colors/Error/50 for light mode and Colors/Error/500 for dark mode. I don’t know everywhere this variable is used and that’s a problem in developing a new component where Colors/Error/500 doesn’t work well in dark mode.
I can solve this by creating a set of component variables, but that’s considered a hack at this company.
Seeing all the components where bg-error-primary is used would help me make an informed decision about whether I could change the dark mode property by getting scope on the impact of the change.
