Unable to use figma.ui.reposition()
  • February 10, 2023
  • 10 replies
  • 510 views
Alex_FG
My typings file is updated to 1.58.0 but I’m still getting
error TS2339: Property ‘reposition’ does not exist on type ‘UIAPI’.
during compilation, but at run time everything seems to work. 🤷
Is there something else I need to update?
tank666
  • February 10, 2023
Perhaps your compiler is referring to some other (old) typing file.
Alex_FG
  • February 10, 2023
Is there something else I can update that would could fix this?
tank666
  • February 10, 2023
I don’t know what you are using, so my answer will be general: change or provide a new path to the typing files in your IDE.
Alex_FG
  • February 10, 2023
Oh I’m sorry, I’m using VS Code with a standard installation as per the intro tutorial (might be an older tutorial because now there’s something about an installer and I think I remember having to type a bit more).
Alex_FG
  • February 10, 2023
Is figma.ui.reposition() new? I know I’ve been waiting for it for a long time, but I don’t remember seeing it in the docs until I saw it last night by accident. Maybe it’s not properly exposed or something? I’ve updated the typings and did everything I could google to solve this. It still says that it doesn’t find .reposition()
JosephxBrick
  • Active Member
  • February 10, 2023
It’s odd because when you go to the github repository, the file does contain the reposition function:
…but the file in v1.58.0 (under “tags” in the repository) doesn’t have it.
I modified the file locally, and the IDE stopped complaining about it and there were no console errors when run, but it didn’t work reliably - e.g., it only repositioned the window occasionally, whereas the “resize” function used in the same spot worked every time.
  • February 11, 2023
Yes, it is very new, it is not officially released yet.
Alex_FG
  • February 11, 2023
Is there an ETA by any chance, since the API has already been published?
  • February 11, 2023
Figma doesn’t disclose their plans usually. But in my experience it should be released this month since it was already added to typings.
Alex_FG
  • February 11, 2023
So excited for this function! 🤩
