Hi, I am building a UI where I frequently resize frames with rounded corners and I have encountered an animation glitch.
Steps to reproduce:
- Create any frame or rectangle with rounded corners
- Animate it only to change it’s dimensions, leaving the corner radius the same in both states
See the GIF below for result.
This happens regardless to
- the element stroke or fill type
- the smart animation type or speed (you might miss it in fast animations of small transformations but it’s there)
