I’m new to figma and my prototype is not displaying some of the text that I have written when I click play button https://www.figma.com/file/X0SJH0OUVRHoXpuTe38QhF/Untitled?node-id=0%3A1&t=7XagHdEZHrmpL3qC-1 . I understand that my prototype is a bit messy with all frames and etc but how can I fix this quickly?
Hello dear
Welcome to Figma and its community
The solution is an easy one, You have to put your text in the frame and not above or under it.
Since your learning, I suggest use clean layering name so that you don’t get use to messy layering, It causes heavy problem on real products
your layers muse be inside the selected frame
I’m sorry to be annoying but how do I do it? Could you please write an instruction? I tried following few tutorials and clicking buttons (doing it myself) but then when I click Play prototype - that section that I clicked “Frame selection” on - appears as different prototype in my presentation.
Hey @Mykola_Havrylov
No worries, We are here to help
Simply, select the text layers in the picture I attached last time ( you can multi-select by holding Ctrl ) and then drag them into the frame called Design Mykola … and then play the prototype and your problem should be fixed.
I suggest you read this articles to see how layouts and auto layouts works, so can have a better understanding:
