Where do i find component key
Hi, I’m new to Figma and I have a design in my library. I need to get the component key so I can use it in my plugins, but I can’t find it anywhere. Thanks in advance.
Thanks, got it now. Got this error when running my pluggin.
code:
Do you know what could be the cause?
This means the component is not published in the library.
Thanks it works now!
If you are developing a Figma plugin and need to access the component key programmatically, you can use the Figma Plugin API, specifically the key property of a ComponentNode object.
Here’s an example of how you might use it in a Figma plugin:
// Get the selected component
const selectedComponent = figma.currentPage.selection[0];
// Check if the selected node is a component
if (selectedComponent && selectedComponent.type === 'COMPONENT') {
  // Access the component key
  const componentKey = selectedComponent.key;
  console.log('Component Key:', componentKey);
} else {
  console.error('Please select a component on the canvas.');
