Figma Support Forum
When the icon is named with / and being exported, naming error caused the system to interpret it as a path folder when unzipped the downloaded file
I have a file named A/C icon and the system interpret it as a path variable. I don’t know how did the software engineer team parse the name, but I guess this error is not caused on your end. This might be a zip problem at the end.
However, if the zip file was packed on Figma’s end then it might be because of the parsing of the name variable. I don’t know much detail about the technology stack that figma is using, but solving this should be easy if that’s the case.
