In view only mode the sidebar panel with the variants is so small that you can barely see the title associated with it. This problem also exists in normal edit mode, albeit a lot less intrusive. Since the sidebar is not width-adjustable that makes it difficult to explain some variants.
An obvious solution/idea (I don’t know about the technical constraints here) would be to allow these fields to wrap into new lines. But there are other factors to consider holistically, so I leave the thinking to you guys.
This topic is an extension to this problem: Inspect toolbox truncation issues
See screenshots (1 is viewer mode and 2 is editor mode) and description above. I know that spectators could theoretically infer the variant title from the CSS commentary below, but it’s not a great workaround.
Does anyone else think this should be adapted to allow for more readability within variants? Not just the viewer side, but also within the editor itself.
