Figma Support Forum
Two additions to the right click
I would like to propose two additional options to the right-click menu
  1. Share. This would be especially useful when adding designs to Jira tickets. It would save having to always go up to the share button then drop to the bottom of the share dialog. While those could of clicks don;t sound like much, if you do them multiple times a day you start to think there has to be a better way.
    Better yet it would be cool if there were share options that had a Jira search integration so I could just paste or select the Jira ticket number and the frame would automagically be included in the ticket.
  2. Export - While I don’t export frames all that much, it would be nice to be able to do this by simply selecting a frame then right clicking.
Thoughts?
1:
I never thought to look under the copy menu since I normally use shortcuts for all my copy/paste interactions.
Thank you once again, Gleb.
Since the first issue is solved (I guess?), let’s do the following to make the suggestion more clear:
  1. You can create a new suggestion topic specifically for the export feature via right click context menu.
  2. I will close this topic.
How does this sound?
