Triggering component interaction from a separate component
Currently both trigger and action should be defined over the same component which is very limiting. Would be very helpful if we could trigger component interactions from other components.
Example 1- Tabs
To create a simple interactive tabs mechanism I need to create a sperate frame for each of the tabs.
Ideally I could have created an interactive component with different variants and have 3 seperate buttons which would switch between the component variants on click.
Example 2 - radio buttons
Ideally i would like the clicking a radio button would enable it and at the same time disable the other radio buttons. This is currently not possible
