Figma Support Forum
Toggle based keyboard shortcuts
I want to quickly change the text case from Uppercase to Lowercase with a keyboard shortcut. Currently, I have to select the text layer, then select the type details, then change the letter case to Uppercase. I wish I could toggle between the various text cases with a keyboard shortcut.
I want to quickly change the fill of a shape from no-fill to filled, and toggle back and forth. Same for stroke to not stroked, and stroked, and back and forth. Current keyboard shortcut only allows you to remove the fill and stroke, but it’s a one-way shortcut where pressing the shortcut again doesn’t toggle between states.
  1. Add as much context as possible (screenshots, Figma files, mockups, etc.)
N/A
  1. Ask questions to bring the community into the conversation
N/A
