There is a bug on the Prototype UI
There is no issue on cells white boarder.
But I open the prototype mode. It shows the black boarder around those cells.
It looks like this in the design board
Make sure the frame has a solid white background. And there should be no decimals in sizes and positions of objects and frames.
I did. I changed the color to other color and then change it back to white. It works in the prototype, but I reopen the prototype again. it did not work and shows me again the black outline.
I am having this issue as well. There is no border or shadow on any of my elements in my artboard.
However, in prototype mode it shows.
@Candace_Choi for the parent frame does it have a fill set?
It does not.
Got it. If there’s not a fill then the background of the prototype will be shown in any gaps.
You can either add a fill to the parent frame or change the background of the prototype.
CleanShot 2022-01-27 at 12.31.45@2x
Does this issue still happens while the zoom is set at 100%?
I noticed similar visual bugs while the prototype had been set to rescale the visual to a different size, for example while set on Fill.
I consider this to be a render bug caused by insufficient number of precision in the calculation – a similar effect to pixelation or if want to round to pixel perfect each pixel of a circle. :sweat_smile:
Edit:
Oh, it may not be the case here. :man_facepalming:
