Today I tried to copy a frame that has components and I’m getting this message:
When I paste the frame in another document is empty.
This is very weird. Any idea how to fix it?
L
L
Happened to me as well, probably this was some bug, anyway I tried following this thread’s solution but it didn’t help me, have a look if this helps you.
Check if your component name has “.” Or “_” at the beginning, since there’s a bug related to hidden libraries.
If so, remove that and publish again.
Also you can try a non-intrusive change on the component by: going into the variant group, selecting all elements command + A and changing the description field on the right props panel, publish and Check results
