Adding a text box, the box is bigger than the text itself, making overlap other objects.
Create a text box. change the text to Title > the text box gets big, and you can adjust the size of the box (I guess it should adjust to the text size automatically.)
Put another way:
The size of the text box dynamically expands to fit the text (as you add more text or increase the font size). However, the inverse is not true so you end up with larger than needed text boxes that get in the way when trying to select objects.
