Exporting simple circle with shadow to SVG.
On retina display saw aliasing of edge, that is above the shadow.
Did screenshot, zoomed and clearly aliasing is visible.
It’s even more obvious on mobile devices if SVG is brought into app or web.
Tried doing the same with Affinity and Illustrator > no aliasing.
I have the same problem. It looks like the inner-shadow and drop-shadow are rendered as “feBlend” in the SVG. This seems to be the cause of the problems. Does anyone have an idea how I can export it without “feBlend”?
masked are having same problem.
check orange squares , even rounded corners are not aliasing , but hexagon , while being a mask - aliasing…
I’m seeing the same issue on my end
Another example:
A - how it’s in Figma (paying attention to shadow and gradient on green area)
B - Shadow causing aliasing
C - removed shadow in Figma and applied CSS
filter: drop-shadow
manually.C - where is the diamond gradient on the green area??
