Hi,
I embedded my prototype on my website, but by default it is cropped. Is it possible to make it fit? Thanks
Hi,
I believe it is possible, by one of two methods.
Before you generate the embed code, switch the scaling of the prototype to the desired setting (e.g. switch from 100% in the options to fit or fill)
Directly editing the src=
value in the HTML to add %26scaling%3Dscale-down
to make it fit or %26scaling%3Dcontain
make it fill the available space.
Let me know if none of those methods work for you.
The second option worked perfectly! Thank you so much
