Likewise, same problem here.
Having the same bug as well — has created a huge headache and now our team is questioning if there are values elsewhere that could have discrepancies.
Would really love to know when this is planned to be resolved. Really inconvenient and causes a lot of miscommunications.
Same issue Here. When will this issue be fixed?
It’s over 1 year and more. I think this is a serious issue.
WHY IS FIGMA DIDNT FIX THIS STILL NOW?
same here. any updates
Same issue, not working properly even with the latest update
Can’t believe that this issue is still not fixed yet for close to 2 years!!! how long does this actually take to fix? If I were figma I’d jump on this right away, as this bug causes much more pain than the joy those figjams bring
I have the same problem. Maybe Adobe fix this issue…
Still nothing new about this?
You should asap remove wrong specification items out of the Inspect panel, so it does not bring confusion to the developers!
Bump. This has been a pain in our handover process for a while and only now I’ve understood the root of the cause. This needs to be fixed.
Same issue here!
Bump… please fix this Figma or give us the ability to declare font-weight overrides for the Inspect Panel
+1
this issue is causing handoff delays and misreporting of bugs in our team. is the solution in the works? it’s been consistently reported for almost two years now…
Same issue here.
Just sharing another instance of this bug. Brandon Grotesque (Adobe Typekit font) is being used at the weights 400, 500, and 700 in this project, but Figma displays the weights as 390, 420, and 450 respectively. I’m really not sure what the deal is here, but this bug has thrown a wrench into pretty much every design/dev handoff for every project I’ve worked on in the last few years. Our designers specify elsewhere what the weights need to be for a project, but inspecting other components requires us to translate the erroneous values in your head to the real weights.
In screenshot, the selected text box should show 700 as the weight.
We just had the same issue, our devs noticed that the weight was shown as 400 in figma when it should be 700.
Any fix for the font style showing incorrectly in inspect? We updated font styles and the inspect panel is showing the old styles. Super obnoxious as the old style showing is different than the new styles so stuff is being built incorrectly on their side.
