Resizing component built on base component
I’m trying out working with base components for the first time due to the advantages of having everything placed in one place so updates can be done quite quickly.
Previous, when I’ve worked with default components, I’ve found it easy to set resizing properties and constraints i.e that the text in the attached example is always fixed to left, the icon to the right side and the container is always scaling.
But when working with base components where I’ve nested different types of the component I can’t make this work. I think it’s because I’m using Auto Layout for the different versions, but I’m not sure and most likely I’m structuring it all wrong :slight_smile:
Has anyone created a similar base component or is there a better way to handle this? All input is appreciated.
Thanks in advance!
