How do you reset the plugin data? If I use setPluginData
, will the key/value pairs I’ve created remain even after the plugin has closed?
If you set the value to the empty string (
), the key/value pair is removed.
Of course the data will remain since you added it to the node (assuming that node is not removed from the document).
If you set the plugin data for a given node, and you clone said node, will the node and it’s children have new IDs?
Yes, IDs are always unique.
