I have already found this issue but it was closed without a reply. There is no way of UN-component a component. Mainly to revert back to frame status. This is for the master component, not instances.
Is it just me or is there no way of doing this?
I was using the same method, instance and detach, but it seems like just a workaround for smth that could be done with one shortcut.
I found a plugin, but it’s bit weird to use. But yes, that is exactly what I meant. Maybe a shortcut might be helpful in the future.
Thank you both!
