I have a suggestion how to improve the overrides system.
I’ll give first some examples of some challenges i’m facing often:
- My design system has a gauge component with a pointer. I cannot make a component where the pointer angle could be adjusted.
- The system has progress bar components, but I cannot make a component where the progress bar could be adjusted.
- A lot of components have a lot of layer and group hierarchy due to auto layouts and “base components”. Other designers and developers find it difficult to do overrides as they have to navigate through a complex layer stack (and believe me, i’ve tried to keep it minimal
- Even me, as the creator and upkeeper of the design system, have sometimes challenges using components quickly and efficiently due to the complexity of some items.
This is what i have in mind:
- Allowing child elements to be unlocked and clickable, while having parent elements locked. This way i could make most content inside the component locked, while giving fast and easy access to only certain elements to quickly apply overrides.
- Allowing to determine which overrides could be done to an instance per component, and which not.
- Expanding the overridable parameters, so that rotation, size and position would be also overridden, but maybe keeping them not overridable by default like described above.
Whad do you think?
