Problema para conecta 2 cuadros
Hola, he intentado realizar el prototipo para conectar 2 marcos pero no me sale el (+) para conectar con otro y no se que hacer
Thanks for reaching out! I’m going to respond in English as that’s the language we currently support.
When you’re trying to create connections between objects, it’s important to remember that these objects should be frames. It’s possible that your layer might be a rectangle or another shape, rather than a frame. You can only create a connection for rectangles within a frame.
Check out this guide for prototyping in Figma:
If you’re still having trouble, could you please share the file link with access to support-share@figma.com? This won’t impact your billing. I’d like to look into this further for you.
Thanks!
