Plugin panel laggy
When I open Figma plugin panel, the interface will be stuck and not move, but when right click find more plugins in the interface will not be stuck, what is the reason, Is it because I installed too many plugins or is it because of the delayed internet speed?
I remember the original open this plugin panel search plugin very smooth feeling, this delay problem is recently found, I tested the client and the web side will appear this problem of lagging!
I look forward to your reply, thank you~!
Hi @tiantianwanmei I’ve tested the plugin panel from my end but was unable to reproduce any type of lag. Are you connected to the internet through a VPN/Proxy/Firewall and do you have any antivirus software running on your device? It may help to see if you can reproduce this issue if you connect to another network (e.g. mobile hotspot).
