I think there is a bug with text overrides of an element inside a variant when interact with it. In this example, the tab text change with no reason.
See the video herere Figtabs - YouTube
And the file in case you need it.
I’m having the same problem a year later. No solution?
@Alberto_de_la_Puente, in your example, there is a redefinition of the text due to the same names of tab instances and a different order in each variant. The solution is to rename your tab instances, eg: t1, t2, t3. Thus, overrides will be inherited by instance names.
@Manuel21, could you share an example?
I fixed it by changing layer names. I find it bizarre that this IMPORTANT part is not mentioned in any of the tutorials out there…
The criteria for preserving overrides is described in the Help Center article:
https://help.figma.com/hc/en-us/articles/360039150733-Apply-overrides-to-instances#Preserve_overrides.
