Because I want that when scaling the height, the elements are also scaled and don’t break, as it happened to me when scaling the width. I don’t know if I make myself clear.
This does not solve my problem. The scaling is done proportionally and it doesn’t let you set both values at the same time with the Iphone 13 configuration.
Regarding the constraints, it is not an automatic change, I would have to go element by element changing its behaviour.
I understand that figma does not allow to change the size of the frame even if it is between devices of the same type, keeping the aspect of the elements inside it…
Choose Move tool (not Scale) and resize the height while holding Cmd/Ctrl like tank666 said to ignore constraints, the elements won’t move incorrectly like on your screenshot. But yeah it would be better if you learn how to use constraints: resizing with Scale tool is not a great practice for adaptive design. Figma doesn’t know how exactly you want your elements to be scaled if you don’t set constraints.
