Figma Support Forum
Multiple selection of overlapping elements
  1. Selection of elements is harder when they are overlapping.
  2. So when two or more elements overlap e.g. let’s say a bunch of text fields over a box. Now if I want to select only the texts I will have to either lock the box first or move it out of the way to be able to select the texts.
  3. Does anyone else experience this? Is anyone using a plugin or workaround to help solve this?, etc.
SOLUTION
There is a solution for this existing in other softwares. I am not sure if that can be achieved here in figma given that it is online.
You have two different ways to drag select.
  1. If you left click and drag to the right you select everything that your selection box crosses(NOT FULLY INSIDE THE SELECTION BOX)
  2. If you left click and drag to the left then you select everything that comes completely inside the selection box.
For reference check 3d modeling software Rhino3D. The selection of elements there work the same way as explained. Helps in selecting multiple overlapping items.
A post was merged into an existing topic: Cmd+Opt+Drag only selects items in bounds
