The new multi-edit tool is AMAZING! Literally such a game changer.
It has one major limitation though, which is that is only works across a section. I wish I could sometimes select-all the like objects within a single frame (e.g. if I have a repeat pattern on a page, like 5 sections all with a section header, and I want to select all the headers and change the font size).
It would be great if the multi-edit worked at different levels than just the section level, maybe by holding down an additional key or by changing the “level” of the tool in the bottom toolbar, the same way you can change the frame tool or shape tool.
A post was merged into an existing topic: Allow multi-edit selection of matching layers within the same frame
A vote has been moved.
Hey @Alissa_Rubin, thanks for the feedback!
We’ve merged your topic with a similar, existing one here in the community:
