Modal auto layout
Hi,
I’m trying to make a simple modal with auto layout. I started with the title “Submit your contact info”. I added Auto Layout(AL) to the title. Then added a white fill around the text. That turns into a modal box. I set AL to be vertical(↓), so I can add more input fields and a button. The modal will AL the height. Now I want to add a close icon X. That’s where I got stuck. This X needs to be anchored to the upper right corner. If I simply drag the X icon in the modal, it gets aligned to the left side as the rest of the input fields. I want the modal to be stretchable. So when you change the width of the modal, the input fields and button widens. I just couldn’t figure out how to set it up. The closest I’ve gotten is to create another AL around the X. Set this AL to be horizontal (→). This pushes the X to the right. But now the X is above the main title. It still doesn’t look right. And when I resize the modal, the input fields don’t stretch(narrows or widens).
Pleas help. Thanks.
Screen Shot 2022-04-18 at 7.53.49 PM
Screen Shot 2022-04-18 at 7.53.59 PM
Screen Shot 2022-04-18 at 7.54.06 PM
On the right side of your screen on the ‘Design’ pane, you will find options labelled ‘Constraints and resizing’. You would want all the elements inside the auto-layout modal to ‘Fill Container’ instead of being ‘Fixed Width’.
Thanks. I found that you could do the nested auto layout for more complex responsive layout. I think I was having trouble to figure that out. Once I tried nesting, it all make sense now.
I highly recommend to check out this official Figma file:
