Micro interactions
Hello,
I have a problem with micro interactions as i created a button having micro interaction and also navigated it to another page. but when i click it the micro interaction doesn’t work and only the interaction works fine.
how can i resolve this problem.
Interactions set on instances of a component trigger before interactions within the component. So in your example, the instance-level OnClick interaction (go to another page) triggers before the OnClick event within the component itself. The workaround I’ve found for this is to set the instance-level interaction to “On mouse down,” which allows both interactions to trigger.
