How developers can measure the distance between objects in Figma frames in DPs and not in PX in macbook?
Kind regards,
Kind regards,
If you design in DP, your developers will see the DP. Values in Figma are abstract, they are what you imagine them to be. If you think of pixels in Figma as DP or PT. You are probably already designing in DP as it’s almost impossible to design in physical pixels. The values in your design should be the same as in code, independent of the value. Hope it makes sense!
