Make logos not stretch when setting instance swap
Hi all, I have set a component up with an auto layout that contains different logos. I then added the instance swap feature so I can just change the logos instead of creating loads of variants, the issue I’m having is the logos get stretched? This doesn’t happen though when I switch them on the master component…
At some point component instances would have a fixed size, however there is a simple setup that would help you to achieve desired result
