Main icon deleted, component is not working properly
Hi guys!
Is there a way to fix a component when you’ve changed the original icon and deleted the icon that is in this main component? I’ve tried to just change the icon in the component, but it breaks instances in designs. I’ve filmed a video, so it’s easier to understand.
So, is there a way to fix this without restoring the icon (we have a new icon)?
Every help will be much appreciated :pray:
Instead of detaching a property, select the main component and edit the desired component property.
You mean change icon in the main component (copy and replace)? It doesn’t work…
No. Select the “Button” component, find the “right icon” property in the properties panel and edit it (hover over it and click the “Settings” icon (Edit property)).
Yes, this works perfectly. Thank you very much for your help @tank666
