Not sure if this is meant to be possible at the moment, but it would be useful to be able to link from within a dynamic instance. It does work in the master variants so I can do that for now but I think that also means it has to be on the same page?
The use case here is a drop down menu that begins collapsed. When expanded i’d like to link to different screens. Simply example here.
It is a bit clunky as you need to open the instance on the screen, link it, then close it. So perhaps this hasn’t been designed to work, but in theory i think this should be possible?
Thanks!
