I have recently installed AUEX plugin in Figma. However, it does not work properly. After I select the artboard and enable the plugin AUEX, I get the following code: Unable to load code: error.
Could you please advise what might be the issue?
PS. This plugin is also installed in AE.
Contact the plugin creators regarding this error, you are not alone. Since this is an issue with the plugin and not the Plugins API, moving this topic to questions.
@Josh this plugin is not public, it requires manual installation: Install | AEUX
