Is there an Inverse Mask?
I have this:
If I group red and blue together, and yellow and green together, how do I exclude the two groups? If I do an exclude selection it turns into this:
Not only are the colors unified, but the groups’ elements are also subject to exclusion. Unexpected, but still working as intended
For lines cutting through groups, I figured I could rasterize them. It works in that case although you’ll have to maintain the pre-rasterized group.
But in this case, when I did an exclude selection, the 2nd image(very right box) just disappeared
Is there an easier way to do this? Like an inverse mask? Any help is appreciated, thanks in advance!
https://www.reddit.com/r/FigmaDesign/comments/ymkwqn/reverse_inverted_mask/
That answer’s been deleted…
Hi there! I see in the conversation that the subtract selection might help you.
Here is our guide how to use Boolean operation: here
Tutorial video:
Hope this helps, and let’s keep an eye out for any insights or solutions that others in the community might have! Thank you.
