Is there a way to set the auto-layout of a child frame node within a frame node to horizontal so it's children are lined up in a row as opposed to a column but have the child frame node fill the container as well?
I’ve tried everything I can think of but nothing is working.
      const topChildFrame = createFrame({
        layoutMode: 'HORIZONTAL',
        layoutGrow: 1,
        counterAxisSizingMode: 'AUTO'
This is what I have now, but the “topChildFrame” ends up in the middle of the parent container, and it does not fill the container.
I don’t quite understand your question, and this part of the code is not enough to reproduce your result, but you can try manually creating your object in the Figma editor, and then using the console to see all the properties of this object.
And what is the createFrame(obj) function? Is it your own function or is it the figma.createFrame() method?
This is my own function:
function createFrame(options: IBaseFrameOptions) {
  const baseFrame = figma.createFrame();
  baseFrame.name = options.name ?? 'Base Frame';
  if (options.appendToCurrentPage) figma.currentPage.appendChild(baseFrame);
  const width = options?.resize && options.resize[0];
  const height = options?.resize && options.resize[1];
  if (width && height) baseFrame.resize(width, height);
  if (options.layoutGrow) baseFrame.layoutGrow = options.layoutGrow;
  if (options.layoutAlign) baseFrame.layoutAlign = options.layoutAlign;
  // NOTE: counterAxisAlignItems aligns items on the Y axis and primaryAxisAlignItems aligns items on the X axis.
  if (options.counterAxisAlignItems) baseFrame.counterAxisAlignItems = options.counterAxisAlignItems;
  if (options.primaryAxisAlignItems) baseFrame.primaryAxisAlignItems = options.primaryAxisAlignItems;
  if (options.layoutMode) baseFrame.layoutMode = options.layoutMode;
  if (options.itemSpacing) baseFrame.itemSpacing = options.itemSpacing;
  if (options.horizontalPadding) baseFrame.horizontalPadding = options.horizontalPadding;
  if (options.verticalPadding) baseFrame.verticalPadding = options.verticalPadding;
  return baseFrame;
Thanks for the clarification and the function code.
Now the code you provided only creates 1 Auto Layout Frame.
What are the properties of the frame where you want to add the created frame? Does this parent frame have a fixed width?
The parent frame (header frame) is not fixed, and its properties are as follows:
      const headerFrame = createFrame({
        layoutMode: 'VERTICAL',
        layoutAlign: 'STRETCH'
The header frame is a child frame of the “base frame”
base frame
–header frame
----top child frame
----bottom child frame
–form content base frame
–form footer base frame
This is the properties for the base frame:
      const baseFrame = createFrame({
        resize: [1440, 130],
        layoutGrow: 1,
        itemSpacing: 62,
        horizontalPadding: 32,
        verticalPadding: 32,
        counterAxisAlignItems: 'MAX'
createFrame({
        this is useless, everything you write here is ignored, you can't set properties this way
could you please explain why?
Oh, sorry, I thought you were calling figma.createFrame, not your custom createFrame function. In this case all is good.
I solved this issue by assigning the values to each property after appending the child to it’s parent node.
Here is the code:
      const topChildFrame = createFrameAndAppendTo(headerFrame, {
        layoutAlign: 'STRETCH',
        primaryAxisAlignItems: 'SPACE_BETWEEN',
        primaryAxisSizingMode: 'FIXED',
        layoutPositioning: 'AUTO',
        counterAxisAlignItems: 'MIN',
        counterAxisSizingMode: 'FIXED',
        clipsContent: true
This is the implementation for createFrameAndAppendTo:
function createFrameAndAppendTo(parent: ChildrenMixin, args: IBaseFrameOptions): FrameNode {
  const frame = figma.createFrame();
  // Append the child to the parent before settings the properties.
  parent.appendChild(frame);
  for (const [key, value] of Object.entries(args)) {
    frame[key] = value;
  return frame;
