I would like to copy an image adjustment’s values like saturation, exposure… to paste into another image, is this possible?
I want ask this question too!
Hello guys,
Yes it is possible
- Select the image(s) with the properties you want to change
- Select the image with the properties you want to change to
- press the “+” under fill
- Voila!
Here I have first selected the two normal google images(logo3,logo4) and after selected the one with low saturation (logo2)
After the images properties are “synchronized” you are able to adjust them all when selecting multiple with same properties
Hope it helped you,
br /Jan
Sorry, but this is not a solution for the challenge i have, i guess I appreciate the effort tho
It seems to work for you because you have 3 Google logos. Try it with 3 different logos
The Challenge is that I have 4 different Images. One of the images has images adjustments like saturation and exposure. And I want to copy those adjustments to the other images WITHOUT changing the fill-image.
Ahh yes, I see what you mean @Pascal4 .
In that case I don’t have a way to do it , I wonder if there might be a plugin that can do this…?
