Figma Support Forum
Is it possible to copy paste prototype interaction?
Hi, I have recently used XD and found extremely useful the possibility to copy/paste interactions. Is it possible in Figma to select an object with interactions, copy interactions and past them on a different object, even different type of object?
No, it’s not possible. However, if your object is a main component, every interaction you create in it will also be propagated to all its instances on the same page.
I find it very confusing in prototype mode where when you select an item that’s on multiple frames, it will highlight in those other frames too. It makes it look like you can set prototype connections on multiple frames, but you can’t. What’s the highlight for?
It is for Smart Animate.
