Figma Support Forum
Imported text
Hi there …the imported text to Figma does not appear although I select the layer before using the plugin. I used several plugins and it doesn’t solve this issue …any help
What do you mean by “imported text”? What plugins are you using and for what purpose? Can you show screenshots?
when i need to bring text from google sheets …the copydeck text dec doesn’t respond after press enter …after I added the copied and opened link …
But when I use google docs syn it works …and text appears now …
So is the issue solved now?
If you are having issues with a specific plugin, it is better to reach out to the plugin developer directly. You can find their contact in the “Support contact” section on the plugin page.
