I added an Image in Drafts. Then I put a frame around it. I also made sure to move the image to the front so the image is visible. When I clicked on “play” button to present, the frame shows up, but the image does not. What am I doing wrong?
Could you show a screenshot of the layers panel or send a link to the file?
Here it is: https://www.figma.com/file/CbaTfI2iKKxXE71wf0dZcc/Untitled?node-id=0%3A1
It is in drafts mode and if you cannot see the layers panel, then here are individual screenshots:
The “image 2” layer should not be above, but inside the “Frame 3” layer.
Open the layers panel on the left to see this (Menu ⟩ View ⟩ Panels ⟩ Show left sidebar).
Thank you so much. That worked!
