Image Fixed aspect ratio with mask?
I’m using the Vitalii fixed aspect ratio community file, which is awesome. However, I need to mask all my image components to have an angle at the bottom.
I can’t get it to respond. Is there a solution/hack to this?
It sounds like you’re using the Vitalii fixed aspect ratio community file for your images and you want to add an angled mask to the bottom of the image. However, you’re having trouble getting it to work.
One solution/hack that you could try is to create a mask layer using a vector shape with the desired angle at the bottom. Then, you can clip your image layer to the mask layer by right-clicking on the image layer and selecting “Create Clipping Mask”. This should crop the image to the shape of the mask layer and create the angled effect at the bottom.
If you’re still having trouble getting it to work, you could try reaching out to the Vitalii fixed aspect ratio community or the creator of the file to see if they have any suggestions or tips on how to achieve the effect you’re looking for.
