Figma Support Forum
Identify use of stray/missing library components
I am using shared libraries with my design files. I had a shared library with a set of icons using variants, but the library was outdated. I created a new library that has a similar set of icons, but is defined uniquely (for instance, every icon stands alone instead of being in one huge set of variants). My document is using the new library except for 1 component it is saying is missing / in use. Because it’s not identical in the other library, I can’t use a swap to replace it. I also have no way to identify where it’s being used, presumably nested within a component. How can I find where the component is being used, so I can manually replace it?
