Hello, I frequently reuse various social media sized frames and would like to create a library of pre-named sizes so I can just pull up the empty frame and design. What is the best way to create these named/empty templates? Are components the answer? Thanks!
You have a bunch of frame sizes for social media right in the software.
If those are not enough, you can use components, the only issue being you can’t add new content to components. You have at least two options:
- Place your desired component and detach it so that you can add content.
- Make slot components.
Hello! I described method which helps me to create Social media content with using components and frames. description is really long, so you can find the answer here: Behance
